Can someone show me how to change the annotation of a ? that appears over an object when no value has been added. I have attached a pic to show. I only want the Valve data represented at the bottom. Thanks
Solved by patpat79. Go to Solution.
You can easily have your desired output by creating a new annotation or copying the existing one and editing its annotation block and deleting the "upper"field property which you dont want to be shown. Thanks, hope it helps.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
