AutoCAD Plant 3D Forum
Removing Orphaned Fasteners
7 REPLIES 7
Message 1 of 8
TRdesigner82
1545 Views, 7 Replies
I was told not remove orphaned fasteners by the instructor of the class I took when first starting out in Plant 3D. Is this a valid statement? I'm not sure why it would be an option if there was a reason not to do it. Can someone please let me know if the benifits of removing them outweigh the reasons not to???
7 REPLIES 7
Message 2 of 8
TRdesigner82
in reply to: TRdesigner82
BUMP
Message 3 of 8
Honestly, I always get that message, but I learned to ignore it after 3 years.
Attila Vallyon
Message 4 of 8
tylerkerr
I wondered if it did any good. On one project I ran into a case of my VIC clamps showing in the data manager (and then BOM). Orphaned Fasteners did nothing to remove them. I eventually had to change their name in the data manager and delete them every time I ran the report manager.
Message 5 of 8
thebearjed
in reply to: tylerkerr
is this ever going to be fixed. i am soooooo sick of seeing that message pop up when it does absolutely nothing!!!
Message 6 of 8
EricNyh
I've learned to ignore as well.  I don't understand why but, if you have one pipe line that is in two models, and these models are xref'd to each other, if you remove the orphans, it will delete the connection between these models disconnecting the line.
Message 7 of 8
malreid
in reply to: EricNyh
I don;t even have an xref, or any other drawings in the project for that matter, and I still get this error.
What's up with that Autodesk?
Message 8 of 8
dave.wolfe
in reply to: malreid
I teach everyone to ignore it. Started an idea in ideastation:
http://forums.autodesk.com/t5/autocad-plant-3d-p-id/do-not-show-prompt-to-remove-orphaned-fasteners/...
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
”Boost
