I was told not remove orphaned fasteners by the instructor of the class I took when first starting out in Plant 3D. Is this a valid statement? I'm not sure why it would be an option if there was a reason not to do it. Can someone please let me know if the benifits of removing them outweigh the reasons not to???
Honestly, I always get that message, but I learned to ignore it after 3 years.
I've learned to ignore as well. I don't understand why but, if you have one pipe line that is in two models, and these models are xref'd to each other, if you remove the orphans, it will delete the connection between these models disconnecting the line.
I don;t even have an xref, or any other drawings in the project for that matter, and I still get this error.
What's up with that Autodesk?
I teach everyone to ignore it. Started an idea in ideastation:
