AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Removing Elevation from Isometrics
9 REPLIES 9
Message 1 of 10
4156 Views, 9 Replies
How would I remove the Elevations Annotations from automatically appearing in the Isometric Drawings?
9 REPLIES 9
Message 2 of 10
ybogdanov
Project Setup->Isometric DWG Settings->Annotations:
 Desmark option: "Append coordinates and elevations"
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Message 3 of 10
That option only removes the coordinates from the end points. The elevations I am talking about occur whenever the piping changes height.
See example
Message 4 of 10
i added a pdf document as attachment where you can see how to remove the elevation when the height changes. Please let me know if its clear and if it solved your question.
Best regards,
Barend-Jan (BJ) van Zijtveld
Message 5 of 10
Thanks that was exactly what I was looking for.
Message 6 of 10
tarrynd
Hi All
I would like to turn off the coordinates for all points. but I would like to keep the elevation annotations where height changes. I have unticked the appending co-ordinates box for each type of End Connection Annotation. But it is still coming up at points like the attached image. Can anyone help?
Message 7 of 10
dave.wolfe
in reply to: tarrynd
Do a find/replace for CO-ORDS in your isoconfig file, and replace it with CO-ORDS1.  CO-ORDS is the coordinate values, CO-ORDS1 is not a value that is recognized, so will be blank.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 8 of 10
tarrynd
Hi David
Thank you for getting back. I did that and it removed The entire Tap connection. I would still like the elevation there though, Is that possible?
Message 9 of 10
tarrynd
Hi David
Sorry about that, please never mind. That worked perfectly. I have just taken a look at the entire Iso and I dont need the Elevation there.
Kind regards,
Tarryn
Message 10 of 10
dave.wolfe
Yes, I haven't found a way to remove only the E/N (x, y) coordinates.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
”Boost
