How would I remove the Elevations Annotations from automatically appearing in the Isometric Drawings?
Project Setup->Isometric DWG Settings->Annotations:
Desmark option: "Append coordinates and elevations"
That option only removes the coordinates from the end points. The elevations I am talking about occur whenever the piping changes height.
See example
i added a pdf document as attachment where you can see how to remove the elevation when the height changes. Please let me know if its clear and if it solved your question.
Best regards,
Barend-Jan (BJ) van Zijtveld
Hi All
I would like to turn off the coordinates for all points. but I would like to keep the elevation annotations where height changes. I have unticked the appending co-ordinates box for each type of End Connection Annotation. But it is still coming up at points like the attached image. Can anyone help?
Do a find/replace for CO-ORDS in your isoconfig file, and replace it with CO-ORDS1. CO-ORDS is the coordinate values, CO-ORDS1 is not a value that is recognized, so will be blank.
Hi David
Thank you for getting back. I did that and it removed The entire Tap connection. I would still like the elevation there though, Is that possible?
Hi David
Sorry about that, please never mind. That worked perfectly. I have just taken a look at the entire Iso and I dont need the Elevation there.
Kind regards,
Tarryn
Yes, I haven't found a way to remove only the E/N (x, y) coordinates.
