AutoCAD Plant 3D General
thebearjed
Message 1 of 9 (945 Views)
Remove Coords from Isometrics
945 Views, 8 Replies
01-12-2012 07:56 AM
i saw this post..http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Removing-Elevation-from-Isometrics/td-p/3286019...and was wondering if there is a similar way to turn off the coordinates on the isos?
fyi, i unchecked the Append Coords box in project manager.
Employee
TomislavGolubovic
Message 2 of 9 (934 Views)
Re: Remove Coords from Isometrics
01-12-2012 12:41 PM in reply to: thebearjed
In the project configuration, that tickbox for appending co-ordinates is for each type of End Connection Annotation. Make sure you scroll through each option and deselect the co-ord option.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Valued Mentor
Rich.O.3d
Message 3 of 9 (830 Views)
09-25-2012 10:07 PM in reply to: TomislavGolubovic
cant seem to find out how to turn off the x and y co-ords but leave the z co-ord
for 'cont'd on', 'cont'd from', 'connected to' ...etc annotations
ie I just want:
CONT'D ON:
EL + 879
not:
E 896876
N 789769
EL + 879
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Employee
TomislavGolubovic
Message 4 of 9 (810 Views)
09-26-2012 04:48 PM in reply to: Rich.O.3d
in 2012 or 2013 rich?
Tomislav Golubovic
Valued Mentor
Rich.O.3d
Message 5 of 9 (774 Views)
10-01-2012 04:10 PM in reply to: TomislavGolubovic
doh..didnt i say...oops
2012
CAD Management 101:
jhamilton
Message 6 of 9 (528 Views)
03-11-2013 06:34 AM in reply to: Rich.O.3d
Did this question get answered.  I have the same situation and really need the fix.
Valued Mentor
Rich.O.3d
Message 7 of 9 (443 Views)
05-04-2013 04:26 PM in reply to: jhamilton
i havent been using plant for a while, no plant3d jobs in australia apparently (unless youve spent 20 years in an oil and gas job regardless of competence...dont get me started...lol)
this was a core function the way the code was written, its not possible to toggle them individually, they are parsed as a single field entity with Easting Northing and RL
i doubt if this has been changed, I chased this for a while back in 2011/2012 but got nowhere
CAD Management 101:
Employee
TomislavGolubovic
Message 8 of 9 (431 Views)
05-05-2013 03:23 PM in reply to: Rich.O.3d
This is an answer I got about this
Try this, turn off/uncheck the Append Coordinates and Elevation box under project setup for each End Connection Annotation type and open the Isoconfig.xml, search for “ElevationScheme – Elevation” or “ElevationScheme – ElevationExtended” and set the Enable value to “true”, use either 1 or 2 depending on how you want your elevation to be displayed.
Tomislav Golubovic
samans
Message 9 of 9 (287 Views)
09-12-2013 09:22 AM in reply to: Rich.O.3d
Hi Rich
I have same problem as yours and I am just intersted inelevation not X & Y. wondering did you able to find the way to remove x & y values?
Regards, Saman
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
