AutoCAD Plant 3D Forum
Railing on the Tank.
4 REPLIES 4
2579 Views, 4 Replies
I want to install railings on the cylindrical tank. I saw only the flat railing in the upper menu. How can I do railing on the tank?
Thanks for help...
Tank top railing
4 REPLIES 4
ybogdanov
In Plant is not possible to create circular railing, But you can use the AutoCAD commands to do this. Create one vertical pipe and use the polar array. After this sweep command to create top railing pipe and others...or use "donut" command to create the horizontal pipes.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
in reply to: ybogdanov
This is of course a different solution.
But this railings, in Plant3D Data Manager system will not be processed.
Thanks Mr. Bogdanov.
ybogdanov
The part of structure of Plant3D is don't have presision components, because is only use for have reference in 3D. If you want to create perfect structure you need to create it in AutoCAD Structural Detailing 2012.
Yury Bogdanov
Barcelona (Spain)
Dan.Scales
Another option is to draw an AutoCAD polgon that has the same number of sides that the railings would have and then use the endpoints of the lines to place the sections of railings:
This is fairly quick and easy to do.
Dan Scales
”Boost
