I've selected PIPE2STD in Railing settings, but when I draw the rail it shows as square tubing. Any help on why it does this?
Solved by h_eger. Go to Solution.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Thanks for the solution! Your attachement helped me understand the various setting options.
Where are the settings to fininsh the intersection of the toprail and post intersection (see attachement). Also is it possible to have the end of pipe finished with a pre setting as well.
to point 1:
Where are the settings to fininsh the intersection of the post and toprail intersection.
Please check installation I do not have this problem.
Pic: 2013-07-22_2205 is Plant 3D Structure
to point 2:
So is it possible to have the end of pipe finished with a pre setting as well.
sorry not in Plant 3D Structure.
See image 2013-07 22_2210.png-this comes from ASD 2014
r.
Hartmut
Hartmut Eger
Senior Engineer
XING | LinkedIn
