AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
RF vs FF
2 REPLIES 2
TRdesigner82
1172 Views, 2 Replies
RF vs FF
Is there a real reason have RF and FF versions of certain items such as Bolt Sets, Lap Joint Flanges, ect....? This results in the RF or FF being called out on iso's and it causes connection issues. I see no reason for a Bolt Set to be called out as RF(see attached)...
2 REPLIES 2
Indesh
in reply to: TRdesigner82
I think this is an issue in your spec sheet thus in your catalogue try to have the correct naming first.
dave.wolfe
It's mainly for the joint connections.  The flange joints are defined as requiring matches for the PressureClass,Facing, and MatchingPipeOD.  This means the program will only use parts that have those values matching.  So, while it's not "piping" logical, that's how the program works.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
”Boost
