AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
REPORT CREATOR, CALCULATED FIELDS - HOW TO TURN type field STRING INTO DOUBLE?
17 REPLIES 17
Message 1 of 18
alexander..sokolov
2269 Views, 17 Replies
Hello! Please help me! In Report creator I want to calculate area of  sheet metall around tube (after insulation) and for that I need to use thinkness of insulation. Thinkness of insulation it's list in plant 3d for example: 30, 40, 60 .... AND IT'S HAVE TYPE FIELD - STRING, but with this type I can't make any expression, for example: [insulationthinkness]*2+[outdiametr]..... becouse, as I undestand, it have to be DOUBLE type..... and the question is: HOW CAN I CONVERT STRING INTO DOUBLE   for make any expression?
I will be happy to get any advice!!!!)
Thanks!)
17 REPLIES 17
Message 2 of 18
The calculation can be done in Report Creator with a script:
private void cellTotalOd_BeforePrint(object sender, System.Drawing.Printing.PrintEventArgs e)
	if (cellInsThk.Text == null)
        	return;
	if (cellOd.Text == null)
        	return;
	double insThkDbl = System.Convert.ToDouble(cellInsThk.Text);
	double pipeOdDbl = System.Convert.ToDouble(cellOd.Text);
	double totalOdDbl = (insThkDbl * 2) + pipeOdDbl;
	cellTotalOd.Text = System.Convert.ToString(totalOdDbl);
 Result:
Message 3 of 18
Thank you very much!!!)
Message 4 of 18
mcray100500
in reply to: jabowabo
Hello Jabowabo!
I have the exact same problem, but Convert.ToDouble doesn't work... 😞
I did everything as shown above and Report Creator wrote me error, that "Input string was not in the correct format".
What am I doing wrong??? Please help me!
Thanks in advance!
Artyom Khrapov
Refrigeration Systems and Technologies
Message 5 of 18
What is the value of your input string? You need to make sure it is only numerical characters - or you will have to trim out the other characters.
Message 6 of 18
mcray100500
The values of my input strings are "25", "32" and "50".
Artyom Khrapov
Message 7 of 18
mcray100500
To check the "Convert,ToDouble" I did this simple example:
private void label5_BeforePrint(object sender, System.Drawing.Printing.PrintEventArgs e)
	double insThkDbl = System.Convert.ToDouble(label3.Text);
	label5.Text = System.Convert.ToString(insThkDbl);
Result:
See more pictures in attachments
Artyom Khrapov
Message 8 of 18
jabowabo
in reply to: mcray100500
Not sure what the problem is.  You may have a hidden character in your property such as a space or new line.  Try this (not tested):
	string numStr = label3.Text;
	numStr = numStr.Trim(); // <-- this is the typical way to trim spaces, etc. in c#.  I assume it will work with report scripts.
	numDbl = System.Convert.ToDouble(numStr);
	newNumDbl = numDbl + 2; //<--do your math here
	string newValStr = System.Convert.ToString(newNumDbl);
	label5.Text = newValStr;
Message 9 of 18
mcray100500
Jabowabo, thank you for your answer!
But I made some experiments and figured out, that spaces doesn't causes the error. If the "Insulation thickness" value is "_50" or "50_" and even "5_0", program calculates correctly and the error doesn't occur.(see the picture below).
Script for this picture:
	if (label3.Text == null)
        	 return;
	if (label4.Text == null)
        	 return;
	double pipeOdDbl = System.Convert.ToDouble(label4.Text);
	label5.Text = System.Convert.ToString(totalOdDbl);
 I found, that the error occurs when the "Insulation thickness" value is empty. But I don't understand why this is happening, because I thought, that the "if(label3.Text == null) return;" should solve this problem. Or is this not as?
Artyom Khrapov
Message 10 of 18
jabowabo
Try this:
if (System.String.IsNullOrEmpty(label3.Text))
        	 return;
if (System.String.IsNullOrEmpty(label4.Text))
        	 return;
Message 11 of 18
mcray100500
Yes! It work!
Artyom Khrapov
Message 12 of 18
jamie.norbury
Having a similar problem with the above.
Doing a calcualtion for velocity. When trying to convert the maxflow.Text to a double I get an error that the input string was not in correct format.
The cellSize.Text works fine. Both are strings.
private void maxvelo_BeforePrint_1(object sender, System.Drawing.Printing.PrintEventArgs e) {
double cellSizeDbl = System.Convert.ToDouble(cellSize.Text);
double maxflowDbl = System.Convert.ToDouble(maxflow.Text);
double totalDbl = (maxflowDbl / (((cellSizeDbl/1000)* (cellSizeDbl/1000)) / 4 * 3.142)) ;
maxvelo.Text = System.Convert.ToString(totalDbl);
Message 13 of 18
jabowabo
in reply to: jamie.norbury
Are you checking your cell values with 'IsNullOrEmpty' before passing them to the ConvertToDouble?
Message 14 of 18
jamie.norbury
Thanks. Missed that on previous post.
Is there a way to leave the result as blank if one of the field is empty? Also to limit the number of decimal places?
Thanks in advance for your help.
Message 15 of 18
jabowabo
Something like this (not tested):
// check if empty values
if (System.String.IsNullOrEmpty(cellSize.Text) || System.String.IsNullOrEmpty(maxflow.Text))
     // leave cell blank
     maxvelo.Text = "";
else // values are not empty
     // round t two decimal places
     double totalDblRnd = Math.Round(totalDbl, 2);
     maxvelo.Text = System.Convert.ToString(totalDblRnd);
Message 16 of 18
Hi guys!!
How can I take the value of a calculated field and assign to a cell?
It seems hard to me figure it out
Message 17 of 18
jabowabo
in reply to: mikael.santospj
You can assign script values via the Properties of the cell.
Message 18 of 18
mikael.santospj
Hi, I still don't figure it out how those scripts works. I see things "Before Print", "After Print", Data Source Demand....
I wasn't ble to find any documentation.
In this example, I am trying to assign the project number to cell90 via script.. just an example:
private void tableCell90_SummaryCalculated(object sender, DevExpress.XtraReports.UI.TextFormatEventArgs e) {
tableCell90. = General_Project_Number.Value.ToString();
not working
There is no debug information. the help is forum and a bit of Google search.
”Boost
