AutoCAD Plant 3D Forum
Quick Substitute ?
1 REPLY 1
339 Views, 1 Reply
Quick Substitute ?
Hello I'm using Pland 3d 2011 and I've got a project, pretty small, around 50 pipes with maximum 5 meters length.
I've come pretty far now and all pipes have been drawn.
Problem is that we want to change all pipes and fittings to 2,0mm wall thickness. I've added parts with that criteria to a spec and changed all parts to that spec. Can I do something in to substitute these parts without having to change on every part, on by one?
Thanks for helping
Dennis Thol
1 REPLY 1
Venkatesan.A
From your explanation I understand the changes you have made in your spec/catalog is a dimension change (wall thickness, dimensional parameter), for such change you can actually use the spec update check option in Plant 3D.
The attached image show where you can find this option in Plant 3D and the help link gives you more information about this option.
HTH!
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
”Boost
