AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Question - Spec Editor and Tool Pallette
3 REPLIES 3
NormJ
447 Views, 3 Replies
Newbie question here ....
I'm trying to add some components to my CS600 tab under the tool palletes.
This is done using the spec editor, correct?
I've closed Plant3D, launched the Spec editor and opened CS600.pspx. I've selected some items and clicked "Add to Spec" and saved. The file updates, but when I relaunch Plant3D the items don't appear.
The project is stored on a network computer. Could this be the reason why t he components are not showing up on my end? - or am I doing something completely wrong here? Thanks!
3 REPLIES 3
patpat79
in reply to: NormJ
Are you sure you are editing the right spec?? I mean, the spec you are using is default, I am just curious if the spec you are editing is your project spec, which is and normally located inside your project folder. Thanks.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
NormJ
in reply to: patpat79
Thanks patpat79, I was not editing the specs inside the project folder. I'm new at this, sorry - but thank you. I've got it now! You're a big help! Thanks again.
martinTstewart_Adsk
in reply to: NormJ
Also, here are some links to resources that cover Catalog and Spec editing in Plant 3D.
How to use AutoCAD Plant 3D Spec and Catalog Editor (AU 2013 Class)
Free P3D 2014 Curriculum.
Specs and Catalogs Editor in AutoCAD Plant 3D
Plant 3D books available from Ascent
Martin Stewart
AEC Support Specialist
”Boost
