AutoCAD Plant 3D General
Valued Contributor
milic.srdjan
Message 1 of 3 (287 Views)
Accepted Solution
Question - Pipe To Pipe Connection
287 Views, 2 Replies
03-21-2012 08:55 AM
I have a New straight Pipe , e. g diameter 30" and I wish to connect to old one , same diameter 30",
but, I can say "head to head" connection.
New straight Pipe have PipeTag , e.g.   30"-1020-AASS
Old straight Pipe have PipeTAG , e.g  30"-1020-AASS-RECO
New Pipe have layer name same as Tag
Old Pipe have name same as Tag
After connection, all pipes keep their layers , BUT BUT...
One straight Pipe take tag from another, and then I have one straight pipe with Tag 30"-1020-AASS, instead one straight pipe, with welding point, and two pipe segments, with two different PipeTags.
Is it possible to avoid this...
Milic
p.s Is it possible to make straight pipe, with several different straight segments with several different PipeTag
Employee
TomislavGolubovic
Message 2 of 3 (269 Views)
Re: Question - Pipe To Pipe Connection
03-22-2012 06:02 PM in reply to: milic.srdjan
Place the length of pipe then add a field weld in the middle of it to split it? Then you can define different line numbers etc for each section, mark them as Existing or New etc.
You can then change the type of weld from FFW/FW to a SHOP weld if you want also.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Autodesk, Inc.
Valued Contributor
milic.srdjan
Message 3 of 3 (259 Views)
03-23-2012 04:44 AM in reply to: TomislavGolubovic
Halo to Tomislav,
Can I give 10 kudos :smileyhappy:
This is great idea, great solution and I think We must put into Plant3D Course...A lot of time You have situation when You must make new pipe directly to old, in special in revamp...
Thank You very much
Srdjan Milic
Spoiler
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
