Hello
i made a script for a "Cabel Tray" - Pipe. it works when i create a custom object but not in the "pipe" routing function. it comes a pipe and not my shape.
have someone expirence with creating scripts and can help me.
i have attched the script and a picture of the routing
thanks
Hermann
Very Nice work you have done. Hats off. Autodesk, pls. help him to resolve also get the similar kind in the software also.
yes, you are right. i hoped that other people had the same questions and can help me. but ok i have also opened a ticket in the supscription center. i think i will recieve a answer 🙂
Unfortunately, there isn’t much we can do in this case, as our Plant 3D pipe is
a custom object that generates the cylinder shape on the fly.
The pipe scripts are actually only used for creating “pipe decorations”, i.e. when
creating flanged pipe, or socketed pipe. In this case, the pipe end types are
taken from the block definition, but the cylindrical. Stretchable part will
still be generated by the guts of the AcPpDb3dPipe.
For plain pipes, no script at all will be invoked, only the “MatchingPipeOuterDiameter” property
from the spec will be used by AcPpDb3dPipe to create the cylindrical mesh.
Sorry for the bad news.
Thanks for reply from Development side. It would be highly appriciable from users, if Autodesk take this case and do development for providing a template for Cable trays in Plant3d space.
Please provide all the shape intelligent in one umbrella. It is not wise decision to use all your suites/ software to obtain the final result,
FYI - I've informed product management about your requests... Fingers crossed!
