How is posible edit the list of last opened projects in Project Manager? I have any 20 projects, and I want to delete any one.
Thank you
Seems like grate tools, but there are this solution in english? This tools is modificate any file of Plant3D where is all reciento projects. It's intresting to know which file is... To modificate it manually.
1. Open the folder "C:\Users\DOCUMENTEN\AppData\Roaming\Autodesk\AutoCAD Plant 3D 2013 - English\R19.0\enu\Support\Profiles\Unnamed Profile“, you can find a file named "Profile.aws".
2. Open the file by notepad, and search for "MRUList". Delete the MRUn(n=1,2,3...) item. Make sure the n value continual.
Thank you very much for solution!
Another question, how do you find this?? There are any document which describe functionality of program?
In fact, there is no document to describe that. We are the only partner with autodesk in China. We have lots of engineers to solve all kinds of problems from the customs who use plant 3D. This is only one of our solution lists.
