We have just started a pilot project using vault functionality in Plant 3D.
Project setup works just fine and so does syncronizaion and check in/out for dwgs.
We have now hit a problem - when trying to change Tag Format on eg. Equipment.
Following thet needed steps - checking out the Project Settings from Vault and checking in after modifying Tag Format seems to work. But when opening Project Settings again - the changes are not there!
For information changing for example Project Description works.
The project is empty with default settings and full admin rights to Vault.
Anyone have a suggestion?
Solved by JarrodMudford. Go to Solution.
Solved by axeborn. Go to Solution.
I share the answer from Autodesk Subscription Support - which works just fine!
You should be able to workaround this issue by clicking another button in the dialog such as "Edit Block" before clicking OK and closing the project setup.
Now Vault understands that something is modified.
This issue is not Vault related. It is ONLY related to the Extension 1 version of Plant3D 2013. Even if you create a project outside of the Vault, that issue still arises.
