is there a way to restrict access to the project manager for end users and only allow admin types to use it. once an admin sets up a project what stops users from going into the project manager and changing things and/or messing up the project.
Solved by Rave.Tam. Go to Solution.
Set permission for Projectsymbolstyle.dwg
The Project Properties is grayed out if it is read only to the user.
