AutoCAD Plant 3D General
Active Member
Message 11 of 16 (203 Views)
Re: Problems with isos dimensions settings
01-03-2014 09:34 AM in reply to: mauro.cabano
The locating dimension on support doesn't want to appear at all!!!!!!!!!!
Distinguished Contributor
jabowabo
Message 12 of 16 (196 Views)
01-03-2014 10:13 AM in reply to: mauro.cabano
At this point it might be best to .zip up your iso style folder along with a small drawing. Someone here may be able to analyze it quicker that way.
Active Contributor
Message 13 of 16 (179 Views)
01-06-2014 06:18 AM in reply to: mauro.cabano
You are only looking at 'default' dimension style. The top right of your clip which you attached to a previous comment, if you drop down that menu and look at the dimension styles for small bore pipe, existing etc etc.
Product Support
gersteb
Message 14 of 16 (167 Views)
01-07-2014 12:26 AM in reply to: mauro.cabano
Hi Mauro, I have noted that you are using pipes with sizes of 50 and 20. By default all pipes which have sizes of 50 or less will be handled by the Small Bore Piping theme (see attached snapshot). So you have to switch from the Default theme to the Small Bore Piping theme on the top right of the frame in the configuration node 'Isometric DWG Settings - Dimensions'. Now you can do the changes as described above. Regards
Bernd Gerstenberger
New Member
Message 15 of 16 (157 Views)
01-07-2014 04:49 AM in reply to: mauro.cabano
Active Member
Message 16 of 16 (108 Views)
01-29-2014 02:45 AM in reply to: mauro.cabano
Thank You all!!!!!
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
