AutoCAD Plant 3D General
PatrickByrne
Message 1 of 3 (483 Views)
Accepted Solution
Problems with Stub Flanges and Collars
483 Views, 2 Replies
07-10-2012 02:39 AM
Stub Flanges: In the attached sample I have 2 pipes joined by stub flanges, this works well in the model until I go to produce an Isometric. The resulting Isometric is in 3 pieces and the Isometric with the stub flanges only shows 2 welds and does not list the stub flange in the material list. I would like the stub flanges and lap flanges to appear in the material list as a separate items.
The End type for the Pipe is PL PL
The End type for the stub flange is LAP PL with an SKEY FLSE
The End type for the Lap Flange is FL LAP with a SKEY FLFL
Collars: Other pipework uses collars on the end of the pipe and bends with a lap a flange behind it. Once again this models correctly but the resulting Isometric does not show any flanges where the collar and lap flange are located. End types and SKEY’s are similar to above.
Thanks for your help.
PatrickByrne
Message 2 of 3 (481 Views)
Re: Problems with Stub Flanges and Collars
07-10-2012 02:45 AM in reply to: PatrickByrne
Just to add, I am using Plant 3D 2012
PatrickByrne
Message 3 of 3 (457 Views)
07-10-2012 08:48 PM in reply to: PatrickByrne
Found the solution.
When I converted the cadWorx stub ends across it set the Iso Symbol Type as LAPJOINT-STUB-END it should have been LAPJOINT-STUBEND
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
