I have a very long building in Plant 3D 2014 and if i create ISO drawing, Plant places dimensions from first axles starting point. It would be greate if program would recognise nearest building axe if it gives dimensions for pipe. At the moment i need to use Offset location override for every iso drawing and also change axles naming manually.
Any suggestions how to automate this would be appreciated.
cheers
Solved by dave.wolfe. Go to Solution.
Beginning in 2014 Ext 1, you can save the Advanced Default like location overrides in the style. Then you could have a style with the location as normal, and one with it overriden.
