HI all
I need that one "tag line" appears in one drawing, if you see my example you can see that it´s only yellow line with the same tag and plant 3D generate 3 drawings...
Have you tried setting the "MaxDirectionChanges" in IsoConfix.xml to 0?
Have a look att the thread pasted below, maybe that will sort your problem as well.
//Mikael
THANKS YOU!!!
I´m very noob at the moment, the solution was "Force Iso onto one sheet" when you generate a iso drawing in the advanced options...
So easy
