I HAVE MADE THE MODEL OF PRESSURE GAUGE, TEMPERATURE INDIACATOR ETC.
WHEN I TRIED TO ADD IN CATALOGUE BY "CREATE NEW COMPONENT", IN COMPONENT CATEGORY THERE IS NO "INSTRUMENT CATEGORY".
THEN I ADDED INTO THE "VALVE CATEGORY" IN ISO SYMBOL SKEY AND ISO SYMBOL TYPE KEPT BLANK. AND FINALLY ADDED INTO THE SPEC.IT IS COMING INTO THE MODEL PERFECTLY.
PROBLEM IS IN ISOMETRIC. IN ISOMETRIC NO SYMBOLS & TAG NO. LIKE "PIT-3452" ARE NOT COMING.
CAN ANY BODY HELP ME TO SOLVE THIS PROBLEM (STEP BY STEP).
Here are two great links that go through the step by step process of what you are trying to do. These links should help.
Custom Components in AutoCAD Plant 3D
Create new Symbols for Isometrics in AutoCAD Plant 3D
Here is another link you might not be aware of that helps explain Isometrics in more detail.
De-mystifing AutoCAD Plant 3D Isometrics
Quentin Contreras
Technical Support Specialist
