AutoCAD Plant 3D General
Member
info
Message 1 of 4 (427 Views)
Plantpartconvert AutoCad Plant 2014 port cnt <0>
427 Views, 3 Replies
10-09-2013 02:19 PM
Dear all,
Port number <0> after plantpartconver command in Plant 2014.
 <?xml version="1.0" encoding="UTF-8"?> -<BlockInfoCollection xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
-<blockInfoList>-
<block>
<name>DCV3_DN15</name>
<portCnt>0</portCnt>
<imageName>DCV3_DN15-1346090_1_WEB.dwg_DCV3_DN15.png</imageName></block></blockInfoList></BlockInfoC...>
But no problem in Plant 2013 making the same procedure.
What could be the reason?
Product Support
Martin_Stewart
Message 2 of 4 (400 Views)
Re: Plantpartconvert AutoCad Plant 2014 port cnt <0>
10-10-2013 10:19 AM in reply to: info
Sorry for the inconvenience here. This is a known issue that will likely be picked up in the next service pack. See this link for workaround:  http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22088428&linkID=14116967
Martin Stewart
Support Specialist
Product Support
Member
info
Message 3 of 4 (384 Views)
10-11-2013 12:15 AM in reply to: Martin_Stewart
Thank you.
Distinguished Contributor
TRdesigner82
Message 4 of 4 (231 Views)
11-12-2013 11:34 AM in reply to: Martin_Stewart
This workaround does not work for me. After doing this, I'm able to add to a catalog and then to a spec. But once inserted into the model, there are still no end connections so I can't connect anything to it. I really need to get a fix for this...
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
