AutoCAD Plant 3D Forum
PlantPipeAdd problem
6 REPLIES 6
767 Views, 6 Replies
I created this customed knife gate valve, sizes ranged from 12 to 30".
All size work except 22".
Error message, size not in placeholdspec, any idea?
6 REPLIES 6
TomislavGolubovic
There is a placeholder spec thats part of the project, its like a temporary part placement for something that might be missing in a working spec.
Can you post your spec please and i'll see if i can work out what you're missing?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Hi Tom, Thanks for your reply. Please see attached spec. Dennis Tham Mechanical Cadd/Designer Klohn Crippen Berger 500 - 2955 Virtual Way, Vancouver BC V5M 4X6 CANADA D 604.251.8472 | T 604.669.3800 | F 604.669.3835 | dtham@klohn.com | www.klohn.com
Hi Tom,
Is there anyway to edit placeholder spec?
Spec Editor said that I can only edit placeholder in Plant 3D.
See Below.  The imperial size is available.
Thanks in advance.
TomislavGolubovic
Hi, are you sure you attached the spec? Also the images you just added are too small to see?
Tomislav Golubovic
Autodesk, Inc.
Hi Tom,
I am still using Plant 3D 2012.
This is the default placeholder spec.
The imperial size has 22".
The metric size skid over 22".
Do you know if this problem is fixed on 2013.
TomislavGolubovic
I don't understand why you are using the Placeholder spec to build items with. You should be using a CS150, or Stainless Spec, or something that the customer/engineer wants to use. I wouldn't be using the Placeholder spec for anything at all.
Tomislav Golubovic
Autodesk, Inc.
”Boost
