AutoCAD Plant 3D Forum
Plant3d import PCF / SDNF / IFC / XML
6 REPLIES 6
ErwinMeulman
3323 Views, 6 Replies
Plant3D can export to SDNF2.0 and PCF, but has no intelligent solution to import Piping / Structure. I am not a capable to write ObjectARX tools but how can we import ?;
PCF (Piping Component File) files
SDNF files
IFC2x3 files
XML iso15926 files
Tags (4)
6 REPLIES 6
At this time Plant 3D 2014 can only import certain files types. Here is a list of all the files that are currently importable.
http://docs.autodesk.com/PLNT3D/2014/ENU/filesACD/GUID-81A5EE76-39A7-40A4-A5C5-E4921C03B33A.htm
If you do not see the file format you are needing in the list, you are more than welcome to submit a request here.
Autodesk Product Feedback:
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
There are partners that have written importer for various formats. I've heard that more than one has written PCFin.  See what you can find with a little bit of googling.
Peter Quinn
Senior Product Manager
Autodesk, Inc.
Bjschw44
in reply to: PeterQuinn
What about exporting a SDNF file from ASD 2014?
PeterQuinn
in reply to: Bjschw44
Wouldn't you just Xref it rather than go through SDNF out/in?
Peter Quinn
Autodesk, Inc.
Bjschw44
I thought ASD had a SDNF out/in command at one point and I thought Autodesk had a policy of not removing commands from newer versions of software. We have a client that is providing SDNF file formats and we want to use them in both Revit and ASD.
in reply to: ErwinMeulman
replay
”Boost
