AutoCAD Plant 3D General
Active Contributor
Message 1 of 8 (182 Views)
Plant Report - Pipe in Feet & Inches
182 Views, 7 Replies
01-06-2014 03:27 PM
How can I get the quanties to show up in feet and inches for pipe? Right now it defaults to IN which for pipe does nothing for me. I'm sure its a scripting thing but I didnt think I had to take programming classes to edit basic functions in the program. If you have an answer can you step by step the instructions so I can understand it better. I have found some answers but no step by step instructions to apply them. Just 'add it to the script'. I'm using a modification on the default 3D Parts report, if that helps. Thanks
Distinguished Contributor
jabowabo
Message 2 of 8 (173 Views)
Re: Plant Report - Pipe in Feet & Inches
01-06-2014 03:59 PM in reply to: JoeKay
The default reports all (I think) have a function for converting.  All you need to do is make sure your quantity cell calls the function in the scripting area.
1. Find the cell name (tableCell4 in this pic):
2.  In the Scripts section, change the original cell function to your cell name (just change 'tableCell4' as shown below) or Copy/Paste the function and change the cell name to yours:
Active Contributor
Message 3 of 8 (165 Views)
01-06-2014 04:10 PM in reply to: jabowabo
Thanks for the reply but that did not help. I see the table cell, I see the script part in the properties, I can click on it to were the script shows. But I dont get what your telling me to do after that. Sorry.
jabowabo
Message 4 of 8 (158 Views)
01-06-2014 04:20 PM in reply to: JoeKay
There is a "Scripts" button on the ribbon that will open the scripting module. You should see a bit of code almost exactly as circled in my 2nd pic. All you need to do is change the cell name in the code to match yours.
Active Contributor
Message 5 of 8 (129 Views)
01-07-2014 06:46 AM in reply to: jabowabo
Thanks again for the reply. I got it to work now. I was confused cause I had that same script as you circled with the appropriate cell number. It took me switching it to another cell number then back again to get it to work. But it its all good now. Thanks again.
Active Contributor
Message 6 of 8 (117 Views)
01-07-2014 01:35 PM in reply to: JoeKay
New problem. When I do the preview in the report creator it shows my pipe in feet and inches. When I go to export it, it changes back to inches? WHY?! This program over complicates things.
jabowabo
Message 7 of 8 (112 Views)
01-07-2014 02:01 PM in reply to: JoeKay
Excel is changing it.  When you export select the 'Text' option.
Active Contributor
Message 8 of 8 (109 Views)
01-07-2014 02:31 PM in reply to: jabowabo
Thank you again! I owe you a coke.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
