I have a few issues installing the extension 1 of plant 34 2014.
On some pc's I get the error "Error 1327. Invalid Drive K:\"
I have searched for a solution on internet and found that in the register some keys in "user shell folders" could be set to "K:\...".. however, this did not work for me because in de register i could not find any keys refering to "K:\...".
On an other pc i was able to install te extension without any problems. the problem then is that plant 3d won't start up anymore. it alsways says i have to run setup.exe to reinstall plant 3d. when i uninstall the extention it rons perfectly again.
Can anyone help me with these issues? i would really like to see the benefits of the extension.
Thanks in advance.
Corné van Stee
Can you provide answers for the following questions.
Are you trying to install the product on a different drive ?
What OS you have on your machine ?
Have you installed the product (Plant 3D 2014 release version) earlier before installing Extension 1. Did you try to uninstall that ?
Go to temp folder by doing the following.
Start - Run - %temp% - and look for any error logs for Plant 3D installation and send them to me for further investigation.
I don´t know if the log-file was attached properly to my mail, so i hereby send it again using the forum.
We are aware of this issue. Our development is actively working to fix this issue. We deeply apologize for the inconvenience caused.
The workaround is : browse to your source DVD and continue to uninstall it.
Hope it helps.
