This Service Pack does not apply to AutoCAD Plant 3D 2014 Extensions 1 or 2
(Subscription). The updates in this Service Pack are included in Extension 2.
Issues fixed with this Service Pack:
P&ID Drawings
- A new slregroup command has been added to make it easier to manage line groups. For more information, see About P&ID Line (SLINE) Grouping.
- The Edit Sline Group... command was not available in the shortcut menu.
- Control valve substitution did not work. If the substitution palette does not display correctly, you can erase and replace the control valve.
Customer Reported (CER) Defects
- If the program shuts down unexpectedly you can report the error to Autodesk. We have addressed numerous errors reported by you with this service pack. If you reported an error, Thank You!
Fixes that apply to AutoCAD Plant 3D only:
3D Model
- File open command would fail when a drawing is opened that contains custom entities with embedded 3D solids.
- Return bends would not always align with routed pipe.
- Parts created with plantpartconvertcould not be selected in the Spec Editor.
- Ladders and structure did not always display correctly in an Ortho view.
- Butterfly valves placed into a short pipe segment could cause the program to shut down unexpectedly.
Isometric Drawings
- Splitting at a branch would sometimes place components outside the draw-area.
- Tap weld was assigned to the same line number as the olet.
- Improvements to isometric drawings including annotation and dimension placement.
Spec Editor
- Flange thickness in inches did not update correctly for metric projects.
AutoCAD 2014 Service Pack 1 is included in this service pack.
Read me attached
DarrenP
