AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Plant 3d 2013 Fatal error: Out of Memory shutting down
4 REPLIES 4
karthik842
1157 Views, 4 Replies
am in need of help... its too urgent
while using Acad Plant 3d 2013 i got a error Fatal Error: out of Memory Shutting Down.
after that i coudnt open . evey time i open it shows Same error.I have tried of reinstalling also but it doesnt work.
Am using this since 6 months but why its happening like this now.our system config is not bad. Win 8, 8gb Ram , Amd Athlon II x260 3.2Ghz, geforce 610 2GB. Even 3ds Max & Navisworks Running fine But wats wrong with this . plz give me some suggetions instead of formating my PC.
Regards Karthik
4 REPLIES 4
karthik842
in reply to: karthik842
Can any one help me plz
dgorsman
8GB RAM is a little tight for 3D modeling in an AutoCAD vertical.  12 - 16 GB would be better but is no substitute for good modeling practices e.g. logical limits on model sizes, limiting level of detail in modeling.
Have you purged the local data cache?
With P3D and any Autodesk programs closed, go to Run and browse for the utility PnPLocalDataCachePurger.exe
Typical location: C:\Program Files\Autodesk\AutoCAD Plant 3D 2013 - English\...
And have you applied Service Pack 2?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22092894&linkID=14116968
And before that, you could try running a "Repair" (rather than a reinstall), then add SP2.
Martin Stewart
AEC Support Specialist
If you're running 32bit, I urge you to switch your OS to 64bit and the P3D to 64bit.
Peter Quinn
Senior Product Manager
”Boost
