AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Plant 3D sloped pipe to slip on flange
5 REPLIES 5
1084 Views, 5 Replies
Hi I was just wondering if anyone could help me, we have several cases on site where a sloped pipe goes directly in to a slip on flange. Is there a built in tolerence of how much of a angle the pipe can be before it can be connected direct to the pipe and can this angle be altered?
thanks
5 REPLIES 5
Dan.Scales
You can edit the tolerance for your joint in the DefaultConnectorsConfig.xml that is located in the root folder of the project.
This is a section for the connection that you need to edit:
<SlopeTolerance>3</SlopeTolerance>
Dan
Dan Scales
Ahmed1081975
Hi Dan,
I’m sorry to say your answer not sufficient to me please can be more detail with screen snapshot
Ahmed Helal
Dan.Scales
in reply to: Ahmed1081975
I have attached a screen shot from the DefaultConncetorsConfig.xml below:
You need to edit the SlopeTolerance to the required angle.
Dan
Dan Scales
Ahmed1081975
in reply to: Dan.Scales
Thanks For all of you
Ahmed Helal
Hi Dan, I have tried this and I still cannot connect to the flange.
I have a funny feeling though that my project is looking at the wrong DefaultConncetorsConfig.xml file. Is there a way to check if the path to this is correct?
I have changed the tolerance to 5% perhaps this is to much?
Mathew
”Boost
