From the Autodesk Exchange, I have downloaded the GF PE-PP Fittings Catalog to specialize it and use in my projects.
I have been encountering some problems when I tried to make spigot connections. In real life, as you know the Connection point of the spigot parts are not on the edge ıf the solid model, but is a little bit inside of the part, like socket connection. So, when i make piping on Plant 3D, they act like I'm doing a buttweld connection.
But, i could not change my C point since i use the catalog generated by GF.
Is it posibble to change the C point of an formerly identified component in spec editor without using the custom part addition?
Best;
hello
if you use gf catalogue you have to chek evry length of parts they are 90% wrong..........
