AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Plant 3D Specs
3 REPLIES 3
sherring
1612 Views, 3 Replies
Plant 3D Specs
I am new to Plant and just have a couple questions for anyone out there!!
Can plant do the following.
The specs we need in a 3d piping Tank platform are:
Ductile Iron both MJ and DI Flanged (American Cast Iron Pipe
Company)
Carbon Steel CS150 through 300  125lb ANSI and 150lb
Stainless Steel most common schedules 304 and 316
HDPE (Drisco pipe or IPS)
PVC Sch 40 and 80
Drain Waste Vent (Tyler Pipe)
Victaulic
Large database of valves (Plug, Butterfly (wafer and
flanged), Gate, Ball, Check, FCV’s, Globe) (MFR’s - Dezurik, Hammond, Nibco,
ACIPCO, etc)
Any info would be appreciated.
Tags (3)
3 REPLIES 3
bogdanov.y
in reply to: sherring
Yes it is. Without problem.
joego27
Currently there is no HDPE for plant
JohnHolder
Sch 40 / 80 - you will have to make alot of your own fittings.  It is missing quite a few.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
”Boost
