I don’t know if anyone else has had this problem before but the Continuation grips are still showing up on my pipe and fittings after I have routed to them. When you try to continue pipe from these grips an error message saying "Cannot Find Suitable branch in branch table". This effecting all of the specs I have in plant 3d including both custom specs and the specs that came with Plant3D. It also effecting all of the projects that I try to work on in plant 3D. I can still model pipe but I would like to know why they have suddenly appeared out of know where?????
If this is showing for all current and new projects, then you might want to try a repair for Plant 3D. Go to windows control panel, unistall programs, select Plant 3D. This will give you the Plant 3D uninstall window and you will want to select Repair/Reinstall. Try the repair first, if that does not help, then try the reinstall to see if this resolves the issue for you.
Quentin Contreras
Technical Support Specialist
