AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Plant 3D 2015 SP 1 is out
1 REPLY 1
DarrenP
742 Views, 1 Reply
http://knowledge.autodesk.com/support/autocad-plant-3d/downloads/caas/downloads/content/autodesk-aut...
DarrenP
1 REPLY 1
DarrenP
in reply to: DarrenP
AutoCAD Plant 3D and AutoCAD P&ID Updates
Issues fixed with this Service Pack:
Customer Reported (CER) Defects
  • If the program shuts down unexpectedly you can report the error to Autodesk. We have addressed numerous errors reported by you with this service pack. If you reported an error, Thank You!
Plant Vault Projects
  • Fixed an issue when revising P&ID drawings that use off-page connectors.
Fixes that apply to AutoCAD Plant 3D only:
3D Model
  • If you select piping in the 3D model, you can now specify both component properties and connector properties in the properties palette. This makes it easier to specify ISO split points if you split when a property changes.
Isometric Drawings
  • Pipeline annotation text was smaller than expected if it was aligned with the line.
  • Attributes in the ISO title block were not properly aligned unless they were left justified.
  • If a pipe segment has multiple pipe supports, the pipe supports did not spread out evenly in the ISO drawing.
  • Weights for Bolt Sets were not included in the ISO Bill of Material.
Piping Specs
  • A spec update sometimes caused bolt lengths to scale up by 25.4 in metric or mixed-metric projects.
Return to Top
AutoCAD Updates
AutoCAD 2015 Service Pack 1 is included in this service pack. For a list of primary issues resolved see AutoCAD 2015 Service Pack 1.
DarrenP
”Boost
