Hi, just to confirm if is there is a service pack for versión 2014 or just hotfixes?
there hasn't been a hotfix specific to Plant 3d 2014 yet
all the hotfixes apply to the autocad 2014 based products
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=14116968
no service packs either
DarrenP
There is a new hotfix that was just released for AutoCAD Plant 3D and P&ID 2014:
Autodesk AutoCAD P&ID 2014 Tagging Hotfix
Autodesk AutoCAD Plant 3D 2014 Tagging Hotfix
This hotfix applies to AutoCAD Plant 3D 2014. Do not apply this hotfix to AutoCAD Plant 3D 2014 Extension 1 (Subscription). The issues resolved by this hotfix are already included in Extension 1.
Issues Resolved by This Update:
P&ID Drawings
- The Edit sline Group command was not available in the shortcut menu.
- Control valve substitution did not work. If the substitution palette does not display correctly, you can erase and replace the control valve.
- If you change the tag of a line to match an existing line, you are not warned that the line is added to the existing line. An Existing Line Number dialog box now displays. For this hotfix the dialog box displays in English.
