When I generate Ortho views in Plant 3D 2014 parts of the ladder cages are offset in the views.
Is your model drawn at high coordinates?
If so, does moving it closer o the origin solve the issue for you?
Thank,
Dan
Hi Dan,
This has happened on all models I have updated to Plant 3D 2014 so far, some cover a large area and some small and close to the origin.
I have reproduced this in the sample project so will ensure a change request is logged with our development team.
Dan
This is related and similar to the structure bug
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/P3D-2014-Structure-Mode-Bug/td-p/3877701
I tried to export to autocad and it shows up wrong as well.
