AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Plant 3D 2014 Extension 1 - Possible error
1 REPLY 1
Scott.Hallmark
284 Views, 1 Reply
I have noticed that since loading the Extension 1 update, in Orthos I go to update a view and when I do it prompts me that it is up to date and gives me the option to Update or Do Not Update.  I made a change in the model, saved the model and went to the ortho and it says this again.  There is clearly a change and when I select Update View Anyway, it shows the change I made in the model.  So it looks like it is going to prompt me no matter what I do, but it is misleading in that the view is NOT up to date.
** If my reply resolves this issue, please choose Accept Solution **
Scott Hallmark, Design Specialist | Fluor Corporation
Inventor and AutoCAD Certified Professional, Autodesk Certified Instructor | My Plant3D Notes | AU Speaker | ROLL TIDE!
1 REPLY 1
Can you try creating a new project and copy all your drawings and then test whether you could reproduce the same issue.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
”Boost
