AutoCAD Plant 3D General
Member
bdcostley
Message 1 of 9 (977 Views)
Plant 3D 2012 Fatal Error Unhandled e0434352h Exception at fd81cacdh
977 Views, 8 Replies
01-14-2012 08:26 AM
One of our engineers is getting Fatal Error Unhandled e0434352h Exception at fd81cacdh when he opens 2 drawings it happens if he opens the drawings from the local c drive or on a network drive.
Machine Info
Dell Precision T7500
Windows 7 Pro 64 Bit
Six Core Intel Xeon Processor E5645 2.4 Ghz
24 Gigs of Ram
Dual 2GB Nvidia Quadro 4000
500GB Sata 3.0GB/S
Valued Mentor
ybogdanov
Message 2 of 9 (966 Views)
Re: Plant 3D 2012 Fatal Error Unhandled e0434352h Exception at fd81cacdh
01-15-2012 10:41 AM in reply to: bdcostley
Are you prove to open this files with other PC? Wich files are? Could you attach it here?
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Member
bdcostley
Message 3 of 9 (963 Views)
01-15-2012 12:19 PM in reply to: bdcostley
I can open them on a windows xp pro 64 bit pc fine. If they have one of them open at a time they are fine but once they open them both is when it fatal errors
Member
bdcostley
Message 4 of 9 (951 Views)
01-16-2012 07:22 AM in reply to: bdcostley
Now we are getting this error when they are working in any file he doesnt have to open 2 files and once.  AutoDesk any suggestions?
Valued Mentor
ybogdanov
Message 5 of 9 (947 Views)
01-16-2012 07:53 AM in reply to: bdcostley
It's dificult to say what is it. Can you attach you file here?
Yury Bogdanov
Barcelona (Spain)
Member
bdcostley
Message 6 of 9 (944 Views)
01-16-2012 08:27 AM in reply to: bdcostley
When they get the error message again I will attach the error logs.
Thanks for the help
Employee
Message 7 of 9 (874 Views)
01-19-2012 04:19 PM in reply to: bdcostley
Looking atthe dmpuserinfo.xml, it seems like the fatal error is due to one of the ribbon component. Can you try the following and see if that avoids the fatal error?
1. Open the application
2. type ribbonclose
3 quit and restart the application
4. Now open the files and see if they open fine.
I understand this is not a workaround, but wanted to check if the ribbon UI is the actual cause of the issue.
Sankar Ganesh
Sr. Principal Engineer
Autodesk Plant Solutions
Autodesk, Inc
Member
bdcostley
Message 8 of 9 (847 Views)
01-20-2012 08:57 AM in reply to: bdcostley
It doesnt fatal error with the Ribbon turned off.   Let me know the next step.
Employee
Message 9 of 9 (841 Views)
01-20-2012 10:54 AM in reply to: bdcostley
Good to know that the fatal error doesn't occur once the ribbon is closed. May be that the ribbon components were not installed properly. Can you try repair install option and see if that helps? Also make sure that you have the
"AutoCAD and AutoCAD LT 2012 SP1 Ribbon Hotfix" installed as well. You can find that at
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18022638&linkID=9240618
Sankar Ganesh
Autodesk, Inc
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
