Good Day
Trying to get the obvious to work in AutoCAD Plant 3D as Usual
Maybe the method incorrect, but the drawing functionality in Plant 3D changes the Data input sizes?
The sofware application should rather generate an error!!! than change the input parameters AutoDesk??????
If anyone could give some guidance how to achieve below.
Want to enter a Flanged Swept Tee
With the sizes indicated on image below on the LHS.
Data entered but Plant 3D Produces the Swept Tee on the RHS with incorrect sizes.
Below is the data that has been enterd into the specification.
Want to enter a Flanged Swept Tee, Cut Back to 82°
The sizes have been calcutaled as indicated in image 1, and are correct
these sizes entered into Piping Specification - Yet Produces the Incorrect Moddled Item?
Yes i understand that the Swept Tee is not a standard item.
We have to change the Angles as there are fabricated lined fittings that have a 8° slope.
So this is a Specification Component.
Anyone that has a better idea to get AutoDesk Software to generate what we require, we would much appreciate.
Best Regards
Richard
What numbers do you have for O41-43? Those control whether the dimensions used for L1-L3 are to face of flange or back of flange.
Hi There
Sorry for delay - was away for the last 4 days.
Config as below - which works for the 90° Swept Tee's?
Regards
Richard
