AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Piping Connection Settings
5 REPLIES 5
blorich
778 Views, 5 Replies
I am using 2013,  and what I am trying to do is allow Pressure Class 125lb flanges to connect to Pressure Class 150lb flanges (and allowing it to connect to valves), since in the field they will connect because bolt holes and dia are the same.
I have gone into the project setup, gone to the Plant3D DWG Settings> Piping Connection Settings, and from the joint setup dialog box and tired to modify all the required and option fields. Have yet to be succesful.
Does anyone know how to change these to allow different pressure classes or other values to be interconnected?
5 REPLIES 5
Venkatesan.A
in reply to: blorich
Hi Can you post the screen shot of the settings you did in the project setup?
Venkatesan.A
Support Specialist
Product Support
Rich.O.3d
go to your joint settings....find the FL to FL joint
click modify, you will see pressure class with a ticked box saying somthing like required match.
if you detick, it will give you a warning when you try to do this kind of connection but still allow it to connect. if you completely remove the pressure class from the reequired matches field, you will just be able to make connections regrdless of pressure class...NB I do not recommend complete removal
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
dave.wolfe
Go To piping connection settings, select your FL to FL joint.   Select Modify, select Pressure class under property matches. Click Matching values, enter 125, 150.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Rich.O.3d
in reply to: dave.wolfe
ahh...have they managed to get the matching values working in 2013
they didnt work in 2012 version, i havent had a chance to retest them yet
CAD Management 101:
blorich
in reply to: Rich.O.3d
Thanks all for the replies. I will try again to get this to work and will let you know if it works.
”Boost
