AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Pipework Loosing properties
4 REPLIES 4
418 Views, 4 Replies
Hi
I have pipework loosing its properties.
I had drawn CS150 spec pipe run with bends etc, when it was hovered over it gave me the normal hover properties box.
About a week later and it has been moved about and other work done in the adjacent area, gone back to alter it and it has lost its Plant 3d grips and now has only its layer ?
Any help - these seems to happen alot
Any help appreciated
Darren
4 REPLIES 4
Dan.Scales
We have had a few reports of this issue occurring for users and our development team are currently investigating the problem.
Unfortunately at the moment the only fix for pipes that have lost the correct properties is to redraw.
With regard to the cause, we believe it may be related to selecting very large numbers of components at the same time although it is proving to be difficult to reproduce.
Dan
Dan Scales
Dan.Scales
in reply to: Dan.Scales
Could you confirm if your projects are SQLite or Server based?
Dan
Dan Scales
Hi Dan We are Server based. Regards Darren Goodman CAD Coordinator Direct: 01480 326317 Mobile: 07966 233629 darren.goodman@imtech.co.uk Joint Venture between Galliford Try & Imtech Process Ltd, Anglian Water - Spencer House Hurricane Close (Off Spitfire Close) Ermine Business Park Huntingdon Cambridgeshire PE29 6XY www.imtech-process.co.ukOur Vision: "To be the first choice engineering and delivery partner for the water, waste and energy industries" P Before you print please think about the ENVIRONMENT
Dan.Scales
Thanks for the information.
I will pass it onto our developers.
Dan
Dan Scales
”Boost
