AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Pipesupports on sloped pipe fail!
0 REPLIES 0
Message 1 of 1
sap_joakim
394 Views, 0 Replies
Have problems snapping an support on a sloped pipe in a 3D model. Previous versions of plant 3D had no problems doing this. as you can se in the picture. The support at the bottom is made in a prevous version (2012) and then megrated to 2013, and now when i want to continu adding supports it does not orientate corectly as you can se. Is there an setting for this or an hotfix ?
I use 3d snapp to posision the support,
In 2012 the sopport orientated corectly on the sloped pipe without any problems.
Regards
Joakim
0 REPLIES 0
”Boost
