AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Pipe line number tag issues
6 REPLIES 6
Stumble
525 Views, 6 Replies
I have noticed a few lines in my model where the components have line number tags correctly associated with them, however, the line does not appear in the pull-down, in the properties dialog, or the pull-down list in the Part Insertion menu.  When I try to assign one of these line numbers to a component(s), which the only method available is through the New/ Assign Tag dialog, it then instantly switches to "Unassigned".  What is going on with this?
Please help is anyone can.
Bryan Appleton
6 REPLIES 6
m.halal
in reply to: Stumble
I have axactly the same problem.
Did you find a solution ? Somebody can help ?
Thank you
Stumble
Sorry but I did not get a resolution.  It seems to happen mainly when a pipeline is copied to another location.
Bryan Appleton
m.halal
Thank you.
I hope autodesk fix this bug!
neonade
in reply to: m.halal
I have the same problem before, try running "AUDITPROJECT" it did well for me.
Cheers
m.halal
in reply to: neonade
Thank you for you reply !
I try the command but I still have the problem. I can create my line but after that in the properties the value for Line Number is still  "Unassigned".
neonade
after doing that command, have you try assigning tag.
my experience is that the particular line number tag cannot be assigned on any pipeline.
”Boost
