AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Pipe bends on polyline
3 REPLIES 3
tmccar
339 Views, 3 Replies
With "toggle pipe bends" enabled, when I route pipe at 90 degrees a pipe bend is placed automatically. is there a way to apply these bends to a polyline, so that when I select  "line to pipe", bends are placed at each vertex?
3 REPLIES 3
Rave.Tam
in reply to: tmccar
Does bend not shows when you use line to pipe? What does it shows then?
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
tmccar
in reply to: tmccar
Sharp corners and pipe ends
Rave.Tam
in reply to: tmccar
Strange, it work perfectly for me in 2013/14.
”Boost
