Does anyone know if there is a way to have a standard symbol auto-inserted at each field weld location on an Ortho Drawing?
I am looking to have a symbol show up so that we can clearly see the location of a field weld. Currently there is just a line which is hard to see unless the scale is large enough.
Are you using Plant 3D 2011 or Plant 3D 2012?
Thank you,
Thank you for the reply back. I will pass this along to the team as a feature request for 2012.
With regard,
Hi Jason
I would like to ask you whether this problem has been resolved? I would also need the option to show welds in orthographic drawings similarly to the weld dots in isometrics.
Thank you.
With regard,
Lukas
