AutoCAD Plant 3D Forum
Pipe Grips disappeared in Autocadplant 2013
9 REPLIES 9
Message 1 of 10
kumarswapan64
1553 Views, 9 Replies
I my computer piping grips have dissapeared? If I open up the same dwg on a different machine and go to the same pipe, they're all there.
Please let me know if anybody have solution.
I have run "PnPLocalDataCachePurger.exe" but the problem is remain there.
Swapan Kumar
9 REPLIES 9
Message 2 of 10
Type OPTIONS at the command prompt, On the Selection tab, make sure your Grips are set to Show grips.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
Message 3 of 10
dennis
in reply to: kumarswapan64
Try toggling the Hardware Acceleration on/off/on
Message 4 of 10
Sorry it's not working.
Swapan Kumar
Message 5 of 10
kumarswapan64
in reply to: dennis
I tried as per your advise, but still grips are not coming in realistic stage. but it is coming in 2D wireframe stage.
Swapan Kumar
Message 6 of 10
This happened to a couple of us on P3D13 too. I think we had to do a reinstall on one machine for a different reason but in the process, the grips came back. Might be the only solution...
Message 7 of 10
JohnHolder
<modeling> tab <Selection> has <Culling> been selected?
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Message 8 of 10
joel_harris
in reply to: JohnHolder
Be sure that the layers containing these piping objects are not locked.
Joel Harris
Designated Support Specialist
Autodesk, Inc.
Message 9 of 10
jcortezBCB25
in reply to: joel_harris
Non of this work in 2017 try
CULLINGOBJ (System Variable) to 0
Message 10 of 10
jblTV3QG
in reply to: jcortezBCB25
This worked, mine was set to 1, if I could mark this as a solution I would - KUDOS to you jcortezBCB25
”Boost
