I my computer piping grips have dissapeared? If I open up the same dwg on a different machine and go to the same pipe, they're all there.
Please let me know if anybody have solution.
I have run "PnPLocalDataCachePurger.exe" but the problem is remain there.
Solved by JohnHolder. Go to Solution.
Type OPTIONS at the command prompt, On the Selection tab, make sure your Grips are set to Show grips.
Quentin Contreras
Technical Support Specialist
I tried as per your advise, but still grips are not coming in realistic stage. but it is coming in 2D wireframe stage.
This happened to a couple of us on P3D13 too. I think we had to do a reinstall on one machine for a different reason but in the process, the grips came back. Might be the only solution...
<modeling> tab <Selection> has <Culling> been selected?
Be sure that the layers containing these piping objects are not locked.
@jcortezBCB25 wrote:
Non of this work in 2017 try
CULLINGOBJ (System Variable) to 0
This worked, mine was set to 1, if I could mark this as a solution I would - KUDOS to you jcortezBCB25
