Does this even work?
trying to create a simple HDPE WYE - fusion weld.
example 400mm
D1 400
D2 400
D3 400
L1 600
L2 1000
O3 1000
L12 -2
L22 -2
L32 -2
A 45
OF -1
"Geometry can not be generated with the given parameters"
Is the parametric WYE just bugged? I double checked it by just drawing it out, and it looks fine.
going to model them manually now.
Hi John,
I can't reproduce this.
Could you add some screen shots so I can be sure I am creating the Wye exactly the way you are?
Dan
Here are two screen shots of both pages of the parametric modeling.
Hi John,
I don't have any problems creating the part with the sizes you are using.
Does the same problem happen for you in other/all catalogs?
Dan
