fane14
Hello I have a question how i can instal a PSV valve diferent diameter and rating inlet 4" 300#, outlet 6" 150#.
What I have to use?
I search in the custom part and I did not find anything.
I search in the catalogs but the same I did not find nothing regarding to PSV.
I found only angle valves....but how I can change the diameter for inlet/outlet to be different?
please help me
thank you in advance
You could setup a new PSV in the catalog. There is a parametric shape for spring loaded PSVs:
One thing to note, when you create a new component such as this, you'll want to double check all of the dimensions for the part since they initially show up in metric instead of imperial.
It's long ago, hope everyone doing well since then.
I am still can't figure out this thing.
How can we fill out the size parameters? especially if you picked multiple sizes
