We are using Plant3d and we are genarating a lot of PID's. I would like to finde a way to transport the PID with all database informations to an IPad.
I tried allready to generate a dwfx file and load it via cloud to my IPad. But unfortuneatly It doesen't work.
Can you please give me any recommondations to finde a solution?
Best regards Andi
Is there a design review app for the Ipad? It should show the properties. You'll have to publish the P&IDs.
http://www.pdoteam.com/2011/10/smart-dwfs-in-autocad-plant-3d-and-autocad-pid/
Thanks for your fast reply...
We still generate dwfx files for internal use... On our PC station in the workshop we still use the designreview to open the dwfx files and it's running perfect.
Now we would like to use IPads... We have allready installed the designreview app on the IPad. The problem is to place the file on the Ipad. We can use the cloud but we would prefer a other method.
The secound problem is we can not open the dwfx with the app on the IPad...
i don't think there is another method
design review for the ipad works directly with Autodesk cloud storage service
DarrenP
DWF is good way to do this. I don't know about DWFx. DWFs include the properties and show up on Design Review on IOS and Android.
Thank you for your help.
We were able to realise it. Unfortuneatly we do not have Internetaccess on each point in our workshops. That is necessaray because the Designreview app works only with the Autodesk cloud. If we can't find a way to load the drawings without using the cloud we need to finde an other solution...
Anyway thanks for your help...
Best regards
Andi
